ΑΓΟΡΑ ΣΚΑΦΟΥΣ ΑΠΟ ΕΥΡΩΠΗ
ΚΑΛΗΣΠΕΡΑ ΣΑΣ..
αν και με την κριση που αντιμετωπιζουμε σκεφτομαι πολυ σοβαρα την εισαγωγη κοινοτικου σκαφους...επειδη δεν γνωριζω ομως και πολλα για τις διαδικασιες που απαιτουνται σας γραφω μηπως και καποιος εχει γνωση επι του θεματος...αφου βρηκα το σκαφος και σε πολυ καλη τιμη επικοινωνησα με τον πωλητη χωρις ακομη να δωσω καποια στοιχεια ενοειται μου εστειλε ενα μυνημα ηλ. ταχ. κοινως mail και μου εξηγει τον τροπο που θα γινει η ολη φαση...σας το παραθετω παρακατω και θα ηθελα αν καποιος ξερει να απαντησει σε καποιες αποριες μου...
If you decide to buy the boat I will send you the boat by a delivery company due the fact I'm quite busy with my work and most of the time I'm out of the country. Do not worry about the delivery costs, I will pay them . It does not cost very much, this is the reason that i will use this delivery company MOVES DIRECT. They will handle the payment, delivery and also the papers transfer.
1) I will make the delivery papers at MOVES DIRECT. After that I will send you a copy of the contract signed at MOVES DIRECT, a copy of my passport and also copy of boat documents.
2) After I will make the papers for delivery the company will require for an advance payment of 20% from the total amount of the boat.
3) After the advance payment will be made the delivery process will start and you will have 2 days inspection period (from the moment you will receive the boat) before your final decision to buy.
Also with the boat will be delivered the papers of the boat.
4) If you will decide to buy the boat then you must pay the remainder of 80% to the delivery company. If you do not decide to buy the boat, MOVES DIRECT will give your money back(20%).
If you want to buy the boat, please send me your information, so I can make the papers for delivery:
Name:
Address:
City:
Postal Code:
Country:
Phone Number:
οι αποριες μου...
1)ειναι ο σωστος τροπος μεταφορας?
2)γνωριζει κανεις την εταιρια μεταφορας?
3)πως μπορω να διασφαλιστω απο απατη?
4)υπαρχει καποιο link που να εξηγει τι διαδικασιες θα κανω εδω στην ελλαδα ωστε να γινει η αγωραπωλησια....π.χ τι χαρτια θα χρειαστει , καποια πιθανως χρεωση και οτι αλλο χρειαστει?
σας ευχαριστω
Σταυρος - Σαμος
Το σκάφος που λες, πως το βρήκες;
Το έχεις δει από κοντά;
Ομολογώ πως είναι πολύ παράξενο το emailπου σου στείλαν.
Ξεκινά λέγωντας «αν αποφασίσεις να αγοράσεις το σκάφος....» και μετά λέει έχεις δύο μέρες από τη στιγμή που θα το παραλάβεις για να αποφασίσεις αν θα το αγοράσεις ή να το επιστρέψεις πίσω.
Μετά λέει πως πρώτα πληρώνεις 20% προκαταβολή για την όλη διαδικασία της μεταφοράς και μετά αν δεν σου αρέσει το στέλλεις πίσω και σου δίνουν όλα τα λεφτά πίσω!!!! Τι είναι αυτό ρε παιδιά; Συσκευή μασάζ από το telemarketing; Μην τρελλαθούμε κιόλας. Είμαι καχύποπτος ή κάτι δεν μας έγραψες σωστά;
Το κόστος μεταφοράς λέει πως είναι δικό του, παρόλο που η τιμή πώλησης έχει προηγουμένος συμφωνηθεί. Υποθέτω πως στην τιμή πώλησης έλαβε υπόψη και τα μεταφορικά πριν την συμφωνήσει.
Το πιο πιθανό είναι ότι είναι η ίδια απάτη με αυτό:
http://www.nautilia.gr/forum/showthread.php?t=15231
Πες μας που το βρήκες.
sto boatshop24.com
http://www.boatshop24.com/web/gr/suc...totalcount=589
mallon prokeitai peri apatis telika...giati paraeinai kali i timi...telos panton den agxonomai kai poly...apla ilpiza se mia kali agora...sas eyxaristo oloys poy apantisate.. ;)
