Year : 2000 yard number 33 Length over all : 13.50 m Beam : 3.99 m
Draught : 2,00 m Displacement : 14,5 t Engine : Yanmar 100 Hp with freshwater cooling Laying : Athens, Greece.
Extra equipment
-.Furling system, Selden Furlex -.Furlin genoa, new 2006 -.Selden Furlin in-mast furling system -.Furling main new 2006 -.Cutter stay with Selden furling system and 28 sqm sail -.Spinnaker 160 sqm with sock -.Spinnaker pole with topping lift -.Spinnaker equipment -.Storm jib , 16 sqm -.Rod kick, gas -.Hydraulic backstay adjuster -.Signal horn in mast -.Teak deck and on coach roof -.Electric windlass 1500 w + 70 m chain and 30 kg Delta anchor -.Heather Eberspächer D5L-C -.Shower at platform -.Electric bilgepump -.Fridge -.Epoxy treatment on hull -.Aluminium shroud protections -.Flexible shaft coupling, aqua drive -.Electric gas solenoid -.Special interior including 2 arm chairs in salong -.Folding table in pentry -.Micro -.Freezer -.Watermaker 220v -.Electric sea water pump in galley -.Shore power with isolation transformer, and charger 75 amp -.Extra batteries -.Battery controller DCC 4000 -.Max-prop 3-bladed feathering propeller -.Spurs rope cutter -.VHF Shipmate RS 8300 Dual in cockpit and navigation -.Raytheon 398 GPS -.Radio/CD player Blaupunkt London + 2 speakers in salong and 2 in cockpit -.RR kombi antenna for VHF and GSM -.Raytheon Plotter/ Radar RL 72 in cockpit with RL 70 repeater in navigation. 2 kw radom antenna in mast. -.NASA Navtex -.Bow thrusters 10 hp -.Tri colour and anchor light -.Raytheon ST 60 , log, depth, wind, close haul and multi display -.Raytheon ST 7000 autopilot -.Echopilot FLS depth sonar -.Lightning protection -.Bow ladder -.Outboard bracket -.2 teak seats at puspit -.Life raft TEAL 2000 Autoflug, 8 persons with stainless steel cradle on deck -.Opening life-lines sb + pt -.Sprayhood extension -.Stainless steel grab rails outside window -.Stainless steel mooring bollards , toe-rail and at cleats -.Stainless steel windscreen -.Folding Davits Bezenzoni G140 Delta -.Bedflex batten system for fore-peak and aft cabin -.Carpet ,Blue -.Fabrics, Blue Manchester
