Εμφάνιση αποτελεσμάτων σε εξέλιξη 1 έως 1 από 1
Θέμα: (π) NAJAD 441 Ιστιοπλοϊκό
    Thumbs up (π) NAJAD 441 Ιστιοπλοϊκό
    NAJAD 441
    Built by : Najad Varvet AB
    Year : 2000 yard number 33
    Length over all : 13.50 m
    Beam : 3.99 m
    Draught : 2,00 m
    Displacement : 14,5 t
    Engine : Yanmar 100 Hp with freshwater cooling
    Laying : Athens, Greece.
    Extra equipment
    -.Furling system, Selden Furlex
    -.Furlin genoa, new 2006
    -.Selden Furlin in-mast furling system
    -.Furling main new 2006
    -.Cutter stay with Selden furling system and 28 sqm sail
    -.Spinnaker 160 sqm with sock
    -.Spinnaker pole with topping lift
    -.Spinnaker equipment
    -.Storm jib , 16 sqm
    -.Rod kick, gas
    -.Hydraulic backstay adjuster
    -.Signal horn in mast
    -.Teak deck and on coach roof
    -.Electric windlass 1500 w + 70 m chain and 30 kg Delta anchor
    -.Heather Eberspächer D5L-C
    -.Shower at platform
    -.Electric bilgepump
    -.Fridge
    -.Epoxy treatment on hull
    -.Aluminium shroud protections
    -.Flexible shaft coupling, aqua drive
    -.Electric gas solenoid
    -.Special interior including 2 arm chairs in salong
    -.Folding table in pentry
    -.Micro
    -.Freezer
    -.Watermaker 220v
    -.Electric sea water pump in galley
    -.Shore power with isolation transformer, and charger 75 amp
    -.Extra batteries
    -.Battery controller DCC 4000
    -.Max-prop 3-bladed feathering propeller
    -.Spurs rope cutter
    -.VHF Shipmate RS 8300 Dual in cockpit and navigation
    -.Raytheon 398 GPS
    -.Radio/CD player Blaupunkt London + 2 speakers in salong and 2 in cockpit
    -.RR kombi antenna for VHF and GSM
    -.Raytheon Plotter/ Radar RL 72 in cockpit with RL 70 repeater in navigation. 2 kw radom
    antenna in mast.
    -.NASA Navtex
    -.Bow thrusters 10 hp
    -.Tri colour and anchor light
    -.Raytheon ST 60 , log, depth, wind, close haul and multi display
    -.Raytheon ST 7000 autopilot
    -.Echopilot FLS depth sonar
    -.Lightning protection
    -.Bow ladder
    -.Outboard bracket
    -.2 teak seats at puspit
    -.Life raft TEAL 2000 Autoflug, 8 persons with stainless steel cradle on deck
    -.Opening life-lines sb + pt
    -.Sprayhood extension
    -.Stainless steel grab rails outside window
    -.Stainless steel mooring bollards , toe-rail and at cleats
    -.Stainless steel windscreen
    -.Folding Davits Bezenzoni G140 Delta
    -.Bedflex batten system for fore-peak and aft cabin
    -.Carpet ,Blue
    -.Fabrics, Blue Manchester
    Price EUR inkl tax : 380.000,00
