Ιστορικές φωτογραφίες της Σαλαμίνας [Historic photos of Salamis]
A 1961 picture of Salamis. The picture is from Nea Eikonografimeni Geografia Atlas tis Ellados by Leonidas Kouvaris (Syropouloi & Koumandareas publishers, Athens, 1964)
I recall the very small boats going from Perama to Paloukia in the 1950s... Very difficult to describe them although in many early pictures of the Piraeus port you will see them next to the Argosaronikos ships
What an experience to travel from Piraeus to Salamina in the early 1960s. The boats were small, wooden, with a small engine and an enclosure where the passengers were sitting sidewise. Some slightly bigger ones had a small bench ("bar" by euphemism) for drinks and sandwiches... We will never know their names, although we have many pictures... Of course unless someone has a list of all these small boats!
Some of the ferries serving Salamina now (or in the last ten years) can be found here (with photos)
http://images.google.com/imgres?imgu...a%3DN%26um%3D1
I forgot to mention that the two main routes in the 1950s and 1960s were:
Perama-Paloukia
Piraeus-Paloukia
But there was also a less frequent route
Piraeus-Selina
One or two times I had seen special boats to Kaki Vigla, maybe chartered
Piraeus-Kamatero-Paloukia boats from the late 1950s as I remember them...
Τελευταία επεξεργασία από το χρήστη Ellinis : 17-10-2017 στις 15:57
ΠΡΑΓΜΑΤΙΚΗ ΜΑΧΗ/ΝΑΥΜΑΧΙΑ ΣΤΗΝ ΣΑΛΑΜΙΝΑ!
Αρχική Δημοσίευση από
BEN BRUCE
T.S.S. APOLLON
Μετα απο τετοιες φιλοφρονησεις μεταξυ των φιλων BEN BRUCE και T.S.S. APOLLON δεν μπορουσα να μην προσθεσω αυτο το φιλμ απο μια πασιγνωστη Σαλαμινια μαχη του 1973 που την θυμονται (ελπιζω) ακομη οι παλαιοτεροι.
Στις 13 Ιουνιου 1973 εγινε στο γηπεδο Σαλαμινας ο ποδοσφαιρικος αγων μεταξυ Ajax Αμστερνταμ και Αιαντος Σαλαμινος (που αν θυμουμαι καλα ηταν τοτε στην Β' Εθνικη!). Το φιλμ που εχουμε στα χερια μας απο τον ΕΟΑ δεν δειχνει οχι μονο την ποδοσφαιρικη μαχη (ναι ο δευτερος κυριος του Ajax (απο αριστερα) ειναι ο Johann Cruyff) αλλα και μια ναυμαχια μικρων πορθμειων ανοικτου τυπου της εποχης, συμπεριλαμβανομενου και ενος αλλου πλοιου πορθμειου με το ονομα ΣΑΛΑΜΙΝΟΜΑΧΟΣ του 1973!
___________________
Φιλικός ποδοσφαιρικός αγώνας μεταξύ Αίαντα Σαλαμίνας και ¶γιαξ στη Σαλαμίνα (0-2)
Φιλικός ποδοσφαιρικός αγώνας μεταξύ Αίαντα Σαλαμίνας και ¶γιαξ στη Σαλαμίνα. Σκάφος κατευθύνεται προς τη Σαλαμίνα. Οι ποδοσφαιριστές του ¶γιαξ Ολλανδίας και οι παίκτες του Αίαντα Σαλαμίνας στον αγωνιστικό χώρο του γηπέδου Σαλαμίνας, πριν από την έναρξη φιλικού αγώνα μεταξύ των δύο ομάδων. Στιγμιότυπα του αγώνα. Ο ποδοσφαιριστής του ¶γιαξ κ. Ρεπ πετυχαίνει δύο διαδοχικά γκολ.
____________________
Από τις συλλογές του Εθνικού Οπτικοακουστικού Αρχείου.
http://mam.avarchive.gr/portal/digit...387&thid=13720
Στην Κυνόσουρα πολλά αγαπημένα σκαριά. Στο Αμπελάκι ΑΓΑΠΗΤΟΣ Ι κ ΝΗΣΟΣ ΡΟΔΟΣ.Laid up.jpgLaid up_ 3.jpg
Τελευταία επεξεργασία από το χρήστη ΒΙΚΤΩΡ ΧΙΩΤΗΣ : 07-02-2013 στις 12:22
Απίθανες και ακρως συλλεκτικές/μοναδικές φωτογραφίες.
Φοβερά ντοκουμέντα! Το καβουρδισμένο σκαρί του ΝΗΣΟΣ ΡΟΔΟΣ δημιουργεί ένα απόκοσμο σκηνικό... Η δε σειρά με τα παλιά κρουαζιερόπλοια είναι όλα τα λεφτά...
ΓΑΛΑΞΙΑΣ, ΠΟΣΕΙΔΩΝ, ΑΠΟΛΛΩΝ 11, ΟΡΙΩΝ, ΟΔΥΣΣΕΥΣ, ΑΧΙΛΛΕΥΣ και ΑΦΡΟΔΙΤΗ στη σειρά. Και αριστερά φαίνεται ένα ΧΡΥΣΗ ΑΜΜΟΣ (το 3 μάλλον) δεμένο στα ναυπηγεία Αργώ.
Υπέροχα ντοκουμέντα απο όλους σας.
Ας δούμε πως ήταν η Σαλαμίνα το 1960 περίπου, φωτογραφημένη απο τη Βροκή.
ΠΑΛΟΥΚΙΑ 1979
1979-1980 Οταν οι χώροι εντός και εκτός Ναυστάθμου,"τελούσαν" υπο διαμόρφωση.
Οι γκουρού του είδους,μπορούν να ξεχωρίσουν πλοία? (δηλαδή μόνο παντόφλες).naytilia.jpg
Laid up 4.jpgΠολύ πριν η συντριπτική πλειοψηφία από εμάς ανακαλύψει το "σπορ", η ευρύτερη περιοχή ήταν ανέκαθεν ο παράδεισος του Ευρωπαίου κ Αμερικάνου καραβολάτρη.
Εκτός από το ΕΣΠΕΡΟΣ το ενδιαφέρον είναι ότι η τσιμινιέρα που διακρίνεται με την κούρμπα, ανήκει στο ΚΑWTHER πρώην ΕΝΟΤRIA. Αγορασμένο από Σαουδάραβες το φορτηγοποστάλι της Αdriatica πέρασε αρκετό διάστημα στην Κυνόσουρα κ αργότερα στην ράδα του Πειραιά μέχρι να παρασυρθεί από καιρό κ να καταλήξει στα βράχια έξω από τα Λιπάσματα.
Άκρως συλλεκτική και σπάνια φωτογραφία! Και αριστερά φαίνεται το ΑΘΗΝΑΙ του Τυπάλδου... Το προσαραγμένο KAWTHER το θυμάμαι να έχει παίξει σε κομματοσυνδικαλιστικές αφίσες το 1997.
- BB code είναι σε λειτουργία
Κανόνες Λειτουργίας
