1. H Vetus έχει τιμοκατάλογο αν κοιτάξεις στο site της. Αυτές οι τιμές (αυτό το a είναι ευρώ) είναι "copy paste" από εκεί:
ELECTRIC BOW THRUSTERS
(excl. panel and connection cable)
BOW2512B Bow thruster 25 kgf, 12 Volt, tunnel diameter 110 mm................................................ .. a
992,50
BOW3512B Bow thruster 35 kgf, 12 Volt, tunnel diameter 150 mm................................................ .. a
BOW5512B Bow thruster 55 kgf, 12 Volt, tunnel diameter 150 mm................................................ .. a 1.313,50
BOW5524B Bow thruster 55 kgf, 24 Volt, tunnel diameter 150 mm................................................ .. a
1.313,50
BOW6012B Bow thruster 60 kgf, 12 Volt, tunnel diameter 185 mm................................................ .. a
1.343,50
BOW6024B Bow thruster 60 kgf, 24 Volt, tunnel diameter 185 mm................................................ .. a
BOW7512B Bow thruster 75 kgf, 12 Volt, tunnel diameter 185 mm................................................ .. a 1.594,00
BOW7524B Bow thruster 75 kgf, 24 Volt, tunnel diameter 185 mm................................................ .. a
1.594,00
BOW9512B Bow thruster 95 kgf, 12 Volt, tunnel diameter 185 mm................................................ .. a
2.280,75
BOW9524B Bow thruster 95 kgf, 24 Volt, tunnel diameter 185 mm................................................ .. a
BOW12512B Bow thruster 125 kgf, 12 Volt, tunnel diameter 250 mm................................................ .. a 2.681,75
BOW12524B Bow thruster 125 kgf, 24 Volt, tunnel diameter 250 mm................................................ .. a
2.681,75
BOW16024B Bow thruster 160 kgf, 24 Volt, tunnel diameter 250 mm................................................ .. a
BOW22024B Bow thruster 220 kgf, 24 Volt, tunnel diameter 300 mm................................................ .. a 4.406,00
BOW28548B Bow thruster 285 kgf, 48 Volt, tunnel diameter 300 mm................................................ .. a
5.503,75
BP1053 Bronze propeller for BOW22024/BOW230HM.......................................... ...................... a
451,25
BP3019 Bronze propeller for BOW28524.......................................... ............................................ a
IGNITION PROTECTED BOW THRUSTERS
BOW5512I Bow thruster 55 kgf, 12 Volt, tunnel diameter 150 mm “Ignition Protected”................... a
1.629,25
BOW5524I Bow thruster 55 kgf, 24 Volt, tunnel diameter 150 mm “Ignition Protected”................... a
1.629,25
BOW7512I Bow thruster 75 kgf, 12 Volt, tunnel diameter 185 mm “Ignition Protected”................... a
2.230,75
BOW7524I Bow thruster 75 kgf, 24 Volt, tunnel diameter 185 mm “Ignition Protected”................... a
2.230,75
BOW9512I Bow thruster 95 kgf, 12 Volt, tunnel diameter 185 mm “Ignition Protected”................... a
2.832,25
BOW9524I Bow thruster 95 kgf, 24 Volt, tunnel diameter 185 mm “Ignition Protected”................... a
2.832,25
BOW12512I Bow thruster 125 kgf, 12 Volt, tunnel diameter 250 mm “Ignition Protected”................... a
3.433,75
BOW12524I Bow thruster 125 kgf, 24 Volt, tunnel diameter 250 mm “Ignition Protected”................... a 3.433,75
2. Εργάτη προτίμα ηλεκτρικό με δυνατότητα να επέμβεις χεράτα αν χρειαστεί. Εγώ σε 11 μέτρα σκάφος (6 τόνοι ιστιοπλοικό) έχω ένα της Lofrans 1000W.
3. ΤΙμές πανιών; Εξαρτάται τι επιλέγεις. Dacron, laminate, με μπανέλες, furling, cross cut, tri-radial.....Υπολόγισε τουλάχιστο 3000 ευρώ σε dacron.
4. Folding προπελες υπάρχουν πάρα πολλες στην αγορά. Από μια μικρή έρευνα που έκανα από τις πιο φθηνές νομίζω είναι η Volvo, κάπου στα 1300-1400 ευρώ για μια 3-φτερη σε διαστάσεις 16Χ10. Το μέγεθος και πάλι εξαρτάται από το σκάφος (αλήθεια τι σκάφος είναι
Μιλώντας για προπέλες επειδή με προβλημάτισε το θέμα, τελευταίος βρήκα στο internet μια μάρκα στην Αμερική που λέγεται Campbel Sailor. Είναι 3-φτερή σταθερή με κάποιο ιδιαίτερο σχεδιασμό που ενώ έχει λεπτά φτερά και μικρές διαστάσεις (ισχυρίζονται ίδια τριβή με μια 2-φτερη "κλασσική" σταθερή) οι επιδόσεις της είναι πολύ καλές.
Ελπίζω να βοήθησα.
